To simplify, I'm specifying DC.
Assumption: charge is define as motion of electrons through solid metal conductor.
When an HV charge arcs from it's conductor across an air gap, what is actually happening? I can't visualize what's happening to the charge and EMF field. What's it doing?
I imagine it's converting to ions when a plasma is formed. Is that all there is to it? It converts to a plasma, continues the matter path to the other conductor and goes on it's way having lost EM field strength to heat and light? Then it converts back to normal electron charge motion as it proceeds down the other conductor to the ground return path??
Hi FrankenPC,
I think you must first change your assumption. Charge is not electrons moving, but the energy to move electrons. So to have a charge is to have an amount of energy stored that can be use to move electrons.
But, you are spot on with ionization (plasma).As the energy builds, its ability to move electron increase. To have 10eV energy (electron volt: typical unit used in particle physics) means I have the energy to
move 10 electrons across 1 volt potential, or to
move 1 electron across 10volt potential.
Air is not an insulator in an elementary particle sense. Say an electron sits somewhere between the earth and the moon (no air), putting some air in between is not going to stop the electron moving across.
First, a side track explanation for the next paragraph: How electrons moves in metal: It moves in metal by pushing an electron in, the one you push in is not the one that came out - like pushing a ping-pong ball into a tube full of ping-pong balls. A ball came out the other end, but likely not the one you push in. Unlike a copper wire, air just doesn't have any "space" for you to push an electron in. Electrons in air are not free to move around like electrons in metal.
Now back to how it moves:
Lets use a Van De Graaff generator as an example (typical in movies). As the charge build on the metal ball, the repulsive force between electron builds. It no longer needs an existing electron-track like a metal wire. As the electron jumps the surface (moving farther out than normal while "orbiting"), it has enough energy to ionize the air molecules next to it. Ionize means separating (air) molecules into + and - part. It gets close enough to disrupt the + attracting to the - thereby disrupting the bond in that molecule. Now the electron has a + near by that increases its ability to go farther out. The +ion is donated by the molecule it ionized. As it moves and ionize the air around it, the ionized air (ions of air molecules) becomes by definition plasma. Plasma is the forth state of matter where +ion and -ion are dissociated (no longer bonded to each other) but the + and - are still in balance. So, in effect, it created a track for itself and a conducting track for other electrons to follow. It enlarges (in a arc) as the following electrons ionize more air widening the track.
Above is somewhat simplified but convey the idea adequately. But in fact, an electron does not even need that. Copper oxide is not a conductor, yet everyday, we flip a switch and light comes on flowing across the oxidized copper switch. Quantum tunneling effect allows the electron to jump across an energy barrier. The lower the jump, the higher the probably that an electron will "tunnel" by "borrowing" energy from nature.
If it does not even need to borrow energy since the charged ball has plenty, it just need a jolt to turn some air into plasma and the (air isolator) barrier now acts like a broken dam. A huge rush of electrons follow. The plasma track created by the "pioneering" electrons IS the conductor.
Rick
