Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Question about matching network
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Question about matching network (Read 1583 times)
promach
Frequent Contributor
Country:
on:
October 06, 2017, 05:25:28 am »
I am trying to apply circuit (c) to
https://www.um.edu.mt/__data/assets/pdf_file/0010/113500/Matching_Networks.pdf#page=7
using the formula Re(Zin) = L1/(C1*RL) computed below with RL = 75 ohm and Re(Zin) = 150 ohm
However when I did the calculation, it does not fit with the values of L=6.12 nH and C=0.73 pF given, meaning the antenna impedance is not matched with transmitter side. Which part of calculation did I mess up ?
Last Edit: October 07, 2017, 09:51:25 am by promach
Logged
Benta
Super Contributor
Country:
Re: Question about matching network
Reply #1 on:
October 06, 2017, 04:02:03 pm »
Your screenprint unfortunately uses a font where there's no difference between "1" and "L" (lowercase)
Logged
promach
Country:
Reply #2 on:
October 07, 2017, 09:05:19 am »
@Benta: Modified as requested.
Logged
promach
Country:
Reply #3 on:
October 07, 2017, 09:50:45 am »
the formula needs to be modified for the case of
complex load
Do I just put R=a+%i*b which implies complex load into the Zin equation ?
Logged
Benta
Super Contributor
Country:
Reply #4 on:
October 07, 2017, 11:02:53 am »
This is a long way back, but IIRC, the matching network has to provide the complex conjugate load to the output (for maximum power transfer).
You have 150 + j75, so the input impedance should be 150 - j75. Same goes for the antenna.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
