I want to mount a bunch bead LEDs in sets of two, with the two LEDs in each set as close together as possible. Example LED:
Common single-LED stars are too big, and result in the LEDs being spaced too far apart. If another PCB exists more suited for my goal, I'd appreciate a tip. But I bet I'm going to have to mount the LEDs directly to my aluminum U-channel. The question is, how?
I can easily insulate the anode/cathode leads from the aluminum with Kapton tape. The thermal pad is trickier, as I've read that some LEDs have an electrically insulated pad, and some don't. Unfortunately that detail is not listed for the LEDs I'll be ordering. If they happen to be insulated, then I'm set, I can just use thermal glue.
However if they don't, I'm not sure what to do. I have some cheap thermal tape from Ebay which will ensure electrical insulation, but given the included warning "don't use this for a CPU or GPU, you will fry it", I'm not sure this would be sufficient for a bead LED either. On the plus side I'll be running these LEDs at no more than 0.5W each, on the minus side that thermal pad sure is a small contact area.
Suggestions?
Here's some more information on the project in case you're interested. I'm trying to build some LED lighting with both relatively high CRI (color rendering index) and PAR (photosynthetically active radiation). It will be placed where it can be viewed directly, so I don't want any blinding points of light, or for it to appear excessively multicolored.
As structure and heatsinking, I'll be using 1" square aluminum U-channel.
Into the open face of the channel, I'll be mounting ChromaLit remote phosphor. This converts royal blue light to white, with a 4,000°K color temperature, and CRI of 80.
Inside the channel, I'll be mounting royal blue LEDs, at 2" center-to-center spacing. Since these will indirectly produce most of the light, I'm choosing 5W Cree XT-E for high efficiency, which will be pre-mounted on stars for good heat transfer and long life. They'll be run at no more than 3W.
Between each Cree will be two other LEDs, one cyan and one deep red. These will fill in the two biggest gaps in the spectrum produced by the ChromaLit, increasing both CRI and PAR. Not much power is needed in relation to royal blue, so 1W LEDs will more than suffice. Efficiency isn't so important either, so cheap no-name LEDs will be used. I've already verified the ChromaLit will pass these two colors without conversion. But it still acts as a diffuser, blending together the colors, with uniformity dependent on how close I can get the LEDs together. That's why I want to avoid using stars on these LEDs.
The final detail is an internal reflector. It may not be optimal, but I'm going to try some decent quality aluminized mylar. I'll cut strips wider than the channel, and punch out holes where the LED lenses are. With its edges glued to line up with the channel's, it should naturally hold a roughly parabolic shape.
I'm still debating the drivers. I might go with Meanwells for convenience. Or I might use cheap Ebay boost converter modules, adding my own current limiting as I've seen others do.
