Thank you all for the answers.
They have been very useful to me. For now I'll settle for being able to measure the noise level of a simple circuit with a LM317 for example.
I know it's hard to find people who have done some preamp to measure these signals, so any input is very helpful for me.
Janne, I want to see that circuit did not understand if the PCB was 6 layers or would have been ideal if they had 6 layers.
My English is not very good and sometimes translators do not do a good job.
Could you clarify that point?.
Of course thanks and waiting for new contributions.
A hug.
Matias.
"Host" PCB was 6 layers so I had to make it so to fit the preamp parasitically into same panel (no incremental cost). It can be certainly done with less layers (all internal layers were just voltage or ground planes), but of course having a stiff ground around is always good for low noise and it helps enormously with noise immunity, which is crucial for this kind of circuit. Here is the schematic attached. It is pretty much identical to Walt Jung's preamp which he used with Audio Precision audio analyzer when characterizing his super regulator. You can find that
here. Look at his 1995 article series, part 2 A has a schematic for a preamp. Since scope is not so sensitive as an audio analyzer, I added a 100x post-amplifier. Thus total gain is around 80 dB. Raw bandwidth is around 1 MHz, so you might want to limit that to get less intrinsic noise and to make more sense in audio circuits.
Here is a picture of assembled PCB:
As you can see, the capacitors didn't quite fit in so I had to improvise somewhat.
I'll post some results later, to get an idea of what kind of performance one might get with this and a DSO. But for quick stats, intrinsic noise seems to be around 20 mV RMS and 178 mVp-p (as seen by the scope), so considering 80 dB (10000x) gain, equivalent input noise voltages are 2 µV RMS and 17.8 µVp-p respectively.
Regards,
Janne
