Hi all,
I'm following along Randy Slone's book and I'm at the stage where I'm looking to assemble the first part of the power supply. It's all scary to me, so I'm looking for help in checking my understanding.
My progress so far:
1. Drilled holes into chassis sides for switch, cord, fuse holder
2. Drilled holes on bottom for lug, transformers
3. "Tied" transformers with a soldering iron: wires grey to violet for 230VAC on primary, wires red and orange for series
4. Soldered ground wire of plug to lug
In the book, it says the 2 transformers (I bought 2x Triad Toroidal VPT48-1040) will be connected in series for the secondary - so I assumed to follow the tying for "series" instead of "parallel". I've included a picture of the wires of the transformer after soldering - am I on track?
Another question is the bolt for the transformer is going to be mounted to the chassis bottom, where the lug with the ground wire will be connected as well. I saw a comment on Youtube where there might be concern for a "shorted loop" - is this the case in my setup? If so, how can I remedy the situation?
I bought the wrong fuse size and I realize I didn't have any high temp wires to hook everything up so I'm currently waiting on those before continuing.
Thanks!
