Hi everyone,
I currently use a GW Instek triple output power in my practical classes at university, shown below. 3 outputs, each having their own +ve and -ve terminals.
I am curious to know if other triple output supplies that have say ±25v and a +6v channel, like the Rigol unit shown below, can use the negative supply output as a 3rd positive output? I mean, because the + and - channels both share a common port, can you power something with the positive rail, using the common as a common connection and then power something else with the negative terminal being used as a common connection and taking the reverse polarity so that the common output (with respect to the negative terminal) can power something else with a positive voltage (that is greater than 6v so using the +6v channel is not an answer I'm looking for
Sorry if that was confusing. Hopefully you all can understand what I am asking.
