Author Topic: Arduino Code Request - Byte Stream to Array  (Read 16657 times)
Offline Chet T16Topic starter
  • Country: ie
    • Retro-Renault
Re: Arduino Code Request - Byte Stream to Array
« Reply #25 on: September 22, 2011, 10:33:33 am »
Looks good  :)
That state machine should allow you to read in the data and do whatever you want with it.
Thanks for the help (everyone!)
I've added in a loop to print the array to a software serial port so i'll give it a test and see what happens
Chet
Paid Electron Wrestler
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #26 on: September 22, 2011, 10:56:26 am »
MyData[Counter-4] = ReadByte;
Counter++;
ops, you are right, i should imaginate and have the picture flowing in my mind :P but still your previous code is not 100% right, so maybe we all got some mistake. thats why i used to extend the possibility, such as...
if ((Counter - 4) <= 38) {
MyData[Counter - 4] = ReadByte;
Counter++;
if ((Counter - 4) >= 38) {
DisplayAndOrClearData(); // another function
Counter = 0;
  • Country: ie
    • Retro-Renault
« Reply #27 on: September 22, 2011, 04:47:53 pm »
Dammit, a hardware issue somewhere
To read the data i need to invert the signal from the ECU which i use this circuit for
I use this with an FTDI cable to read the stream directly and its fine. When there is data coming the LED flashes but when i connect Rx to the arduino rx pin the LED goes out. I just checked at theres 5v at the arduino rx and tx pins. Whats that all about??
Chet
