I have the 3m 8200 series esd mat. I plan on hooking it to a ground from my radiator and also ground from my socket. The monitor requires 2 grounds (3m 732).
Is it unwise to use ground from the wall outlet ? Can I get shocked ?
How can I test the radiator ground to see if it is really earth ? And also how can I test the quality of the ground connection ?
Can a esd mat conduct and short pcbs laying on them ? Is it safe to power up pcbs resting on the surface ?
The 3m 732 ESD workstation monitor applies a voltage of 9v or 16v with < 3ua to test the mat is continually grounded. Can this effect powered pcbs laying on the surface ?
See page 4 here
http://multimedia.3m.com/mws/mediawebserver?mwsId=66666UuZjcFSLXTtMxMaoxF6EVuQEcuZgVs6EVs6E666666--What is the better choice 9v or 16v ? And which is the safer option 10 megohms or 35 megohms ?
Thanks !
