Hello all,
In the part of my life of unmounting electronic gear, I have seen a lot of sticky stuff on PCBs. Stuff like some kind of wax holding inductor coils in old radios, sponge bits with some goo, silicon-like stuff, many kinds of adhesive tapes, etc. But it was in Dave's videos that I first heard about Silastic. By the way Dave, I love your channel! Thank you. Keep up the good work! Best regards.
So, silastic, emh? Well I searched the forum and found some references to it, I googled about it and found its origins and just that it is a good silicon compound used in many applications. But I feel the need for more. So here's "couple" of questions to those that use Silastic or really know about it. Thank you.
1) What is the primary need of Silastic on a PCB? One can see some of it in almost all power supplies, next to the big electrolythic capacitors.
2) When does Silastic get applied to the PCB? Before soldering the components or after?
3) Anyone knows a "clean" way of removing Silastic from a PCB in order to replace the capacitors, or other component embedded in it? Normally I try to pull it of using some plier.
I think that having the answers to the above questions, I can reply myself to the following one, but here goes anyway.
4) If I remove the Silastic in order to replace some faulty component, do I have to put back some Silastic?
A last one:
5) Does Silastic have some kind of electronic friendly spec, like EMI reduction/shielding, temperature dissipation, etc?
Thank you all for any help.
Best regards,
Emmanuel.
