Transformers (and magnetics in general) have always confused me.
Here are some questions I have:
1.
In a situation where a well made transformer is used in the appropriate application, its assumed that roughly all the power is being transferred from the primary to the secondary.
In this case, the impedance measured from the primary is simply proportional to the impedance measured on the secondary and the turns ratio. Correct?
However, from my understanding, when the secondary is an open circuit the transformer appears to be just an inductor from the primary side. Power will be stored in the form of a magnetic flux in the transformer and be returned with a phase shift back to the primary. Now the impedance measured from the primary is no longer proportional to the secondary impedance and the turns ratio.
My mind is having a difficult time grasping the transition between the situation with nearly full power transfer and the situation with infinite impedance on the secondary (no power transfer).
A) I assume there must always be some magnetic flux being returned to the primary depending on the secondary impedance (and maybe turns ratio?). Is there an equation for this?
B) How do you calculate the impedance seen from the primary as the secondary transitions from zero impedance to infinite impedance?
C) When the secondary is at short circuit - zero impedance, does the primary also see zero impedance or does it see the impedance from the inductance of the transformer?
2.
I made my own small transformer using a ceramic ferrite pot core (Using it around 25 kHz).
For the sake of impedance tuning, I created an small air gap (2-3 sheets of paper thick) between the top and bottom halves of the pot core.
From what I've read, the majority of the magnetic flux is stored in the gap rather than the core. I understand the gap is a source of leakage flux.
A) When the magnetic flux in the gap collapses, does the power get sent back to the primary or the secondary OR is the power divided between both the primary and secondary proportionally to the turns ratio?
B) Does the magnetic flux in the air gap collapse at a 90 phase shift like the flux in the rest of the transformer or does it have some funny properties to it?
I've fried over a dozen handmade inverters so I'm trying to understand if theres any funny sudden overcurrent business going on that I'm not calculating.
Thanks in advance!
P.S. For anyone also trying to gain a better understanding of transformer this blog helped me a lot:
http://ludens.cl/Electron/Magnet.html
