1. I have written code for using on chip high speed oscillator for R5F212L4SNFP MCU for maximum 20Mhz speed.
Is below settings & sequence ok?
2. How many nop to be added to get clock stable. currently I have added 4.
void set_system_clock(void)
/* Interrupt disable */
asm("FCLR I");
/* Protect off */
prc0 = 1;
/* cpu settings */
cm02 = 0; /* Peripheral function clock does not stop in wait mode */
cm05 = 1; /* XIN clock stops */
cm06 = 0; /* CM16, CM17 enabled */
cm10 = 0; /* Clock operates */
cm11 = 1; /* On-chip feedback resistor disabled */
cm13 = 0; /* Input ports P4_6, P4_7 */
cm14 = 0; /* Low -speed on-chip oscillator on */
cm15 = 1; /* XIN-XOUT drive capacity high */
cm16 = 0; /* System clock division select bits; no division */
cm17 = 0; /* System clock division select bits; no division */
ocd0 = 0; /* Oscillation stop detection function disabled */
ocd1 = 0; /* Oscillation stop detection interrupt disable */
ocd2 = 1; /* Selects on-chip oscillator clock */
ocd3 = 1; /* XIN clock stops */
fra00 = 1; /* High-speed on-chip oscillator on */
fra01 = 1; /* Selects high-speed on-chip oscillator */
fra20 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
fra21 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
fra22 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
/* let clock get stable */
asm ( "nop" );
asm ( "nop" );
asm ( "nop" );
asm ( "nop" );
/* Protect on */
prc0 = 0;
/* Interrupt enabled */
asm("FSET I");
} /* functin ends here */
