Author Topic: Random unknown ferrite bead calculation  (Read 803 times)
Offline RickieSalad
« on: June 11, 2016, 03:23:18 am »
If someone was feeling particularly ambitious while cleaning and organizing their electronic components and wanted to determine the values of a bunch of random salvaged ferrite beads, is that possible?  Is there a way to measure them, or is it more of a calculation based on sizes and shapes?
I hope this isn't a stupid question.  :-//
Offline KD0CAC John
Re: Random unknown ferrite bead calculation
« Reply #1 on: June 11, 2016, 03:47:21 am »
My limited info is mostly related to RF ham radio .
Toroids  / ferrites come in many flavors , iron or ferrite , maybe starting with either power or RF , with RF having a larger variety or so-called mix's , each mix is frequency dependent .
I guess that the need for IDing is mostly for RF uses , so putting a few turns of wire through & measuring is a start .
A link or 2 to start , http://www.cliftonlaboratories.com/estimating_q_of_ferrite_cores.htm
calculator    http://toroids.info/
http://www.electronics-tutorials.com/basics/toroidcharts_mcq.htm
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 11, 2016, 11:58:32 am »
100MHz oscillator. Set it up as a voltage divider: osc output -- FB -- 50 ohm terminated cable (e.g. scope/speccy/RF voltmeter input).
Measure several values of resistor (0, 50, 100..) first, and undo the voltage divider equation to solve for source resistance.
Now you're ready.  Insert FB, measure the voltage, and (based on the calibration above) calculate its impedance.  You'll actually be measuring the magnitude, which is close enough.  Most FBs will be somewhere between slightly inductive and resistive at this frequency, so it shouldn't be too far off.
FBs are sold by their impedance at some frequency, most often 100MHz, so this is as good a method as any.
I think you'll find the physically larger ones usually have more impedance, but it will also vary significantly with type, as there are three major classes of material used: LF, MF/wideband, and HF.  If you sort them by both size and impedance, you should see a pattern like this, more or less.
Such a setup will also work well for RF inductors in the range of L ~= (50 ohms) / (2*pi*(100MHz)) = 80nH, give or take a factor of 10 let's say.  Or 10x higher inductances at 10x lower frequency, etc.
Seven Transistor Labs, LLC
Bringing a project to life? We can help.
