I am trying to make connection to a range finder, however I am facing some problems.
I am using:
Geekcreit® FT232RL FTDI USB To TTL Serial Converter Adapter Module For Arduino
Suaoki 600M
This is a "closed range finder", but after opening it I found it very similar (but NOT the same) to other chinese products available on ebay
https://www.ebay.com/itm/600m-Golf-Laser-Range-Finder-Module-Speed-Distance-Meter-Measuring-Sensor-M6G4-/292389466291?_trksid=p5731.m3795that offers TTL comunication.
The ebay version has the following description:
Port Type: TTL
Baud Rate: 115200bps
I have tried to connect it (please see the printscreen and photos on how I am plugin things up)
And I try to send the following commands (described on the ebay article)
0d0a4f4e0d0a ON
0d0a4f46460d0a OFF
0d0a4d4f44453d310d0a MODE=1
0d0a4d4f44453d300d0a MODE=0
0d0a4f3d310d0a O=1
But I receive nothing....
The layout of my board is different from the ebay product, so I am really not sure if I am plugging the cable correctly, but with trial and error I think I was able to make a correct connection, because the optic changes the "layout" to continuous range with automatic update of distance (we can see that on the webcam attached to the range finder)... Meanwhile I have tried all combinations of baud rate, etc.. and nothing changed... I never receive anything and also the commands I sent seem to have no impact on the device.
Is there anything that I am doing wrong? or I simply cannot expect that similar boards will work the same way?
