Stupid question, but you are connecting the current monitoring output to the voltage terminals of the DMM and set it to voltage mode, right? In the case of the SMU, you would configure it as voltmeter (e.g. source 0 nA current in the lowest current range, measure voltage). The SMU may provide a higher impedance, if that matters.
Looking at the block diagram in the
user's guide, the volts and current outputs are buffered, so they should not affect the measurements.
What do you mean with connecting the current output leads leads to a shift in current output voltage? How do you measure the current output voltage without the DMM connected?
A bunch of things you could try and see what sticks
- Are the volts and current monitoring outputs connected to anything except the voltmeter inputs? Any connection between the volts and current inputs? For example, is the shield of the BNC cable connected to earth anywhere (the instrument claims to be floating, so the shield may not be at earth potential)? Any kind of multiplexer between the outputs and the meter?
- Does switching the polarity of the voltmeter connections, i.e. connect BNC center to the negative terminal, and shield to the positive terminal, make a difference? The negative terminal is usually tied to guard on the DMM, and hence will have a larger capacitance to earth.
- Does reducing the control loop bandwidth make a difference? I could imagine that the capacitance of the DMM inputs to earth destabilizes the control loop somehow. I understand that this may interfere with the actual experiment, but it is just for troubleshooting purposes.
- Does enabling the low pass filter on the monitoring outputs make a difference?
- Does adding a say 100 kOhm resistor between the DMM and the electrochemical instrument for both the positive and negative terminals make a difference? Make sure the DMM is set to its high-impedance (> 10 GOhm mode), not 10 MOhm. This could help against any noise that the DMM might inject into the instrument.
- Does lowish-value resistor (.e.g. 10 kOhm) between the inputs near the voltmeter make a difference?
Do you have access to one of the frequency response analyzers these outputs were designed to work with? Then you could measure some properties like input impedance and if the shields are connected together or to earth?
