Hmm - ISO-7637-2 contains quite a lot of voltages, not sure where that 45V came from
Pulse 5a (load dump) is a sort of triangular thing, starting at battery voltage, going up to 65-87V in 10ms, then back down, total pulse time 40-400ms, with a source impedance of 0.5-4Ohms. And that's for 12V electrics - 24V is worse!
So, basically, your choice for load dump is to either ride it out by having a PSU that's OK with 90V (plus a bit, as headroom is good...) (and you also need to keep working on cold cranking, which involves being powered off 5V for up to 40ms, so a wide working range...) Or you can turn yourself off and hide until it's over (if that's acceptable), or you can try to soak up the load dump pulse with some device that doesn't mind that much energy, over and over again. (That way lies madness, by the way)
And then there's the -100V transients, just to really annoy your input stage
And then there's the fact that individual manufacturers like to raise the bar a bit further, to avoid getting a reputation for dodgy electrics, and it's the OEMs who have to meet this stuff, so who cares...
I've not got a multi-manufacturer pulse5 table, but here's a pulse1 one:
TI's
www.ti.com/lit/an/snva681/snva681.pdf is probably worth a quick look for how much effort it takes, and I'm not convinced about the bridge stage on the front - that's a bit brave if there are any other ground-relative connections coming out of your box...
(Blind faith reference wasn't really aimed at you, more at world in general!)
Edit: I've just noticed this is in 'beginners'
Much of this stuff can safely be disregarded if you're building something for yourself, and don't mind much if it fails from time to time! OEM standards are painfully high, and a lot of the time defend against unlikely scenarios. The worst case load dump shouldn't happen, and if you're dumb enough to get the jump leads backwards when you jumpstart, then it's your own electronics you'll destroy. It'll be educational. Stick a series diode in, and rate your PSU to survive 45V, and away you go. You might like a fuse, too, since fires in cars are annoying. A software watchdog or other reboot method is handy if you can't reach a reset button or unplug the power. And try to keep the standby current low, nobody likes a flat battery.
That TPS54340-Q1 looks fine. (I imagine it's got an identical, apart from the papertrail) non-Q1 version that's cheaper and more available.
