Hi all,
I don’t know if this is the appropriate place to post this…
I have recently been working with the NXP PCA9685, an I2C controlled 16 channel 12 bit PWM driver.
They are relatively cheap and easy to implement.
A design I am currently working on requires only 2 channels and the board needs to be fairly small. The PCA9685 is a bit of overkill with its 16 channels, and a bit physically large (TSSOP-28).
Can anyone recommend an I2C controlled 2 channel 12 bit (or more) PWM driver in a small SMD package?
I have hunted through Mouser search and cannot find anything suitable.
The device will be controlled by an ATmega328p-au, so the comms to the PWM chip can be either I2C or SPI.
Background to the design: ATmega328p-au, nRF24L01 radio, PWM driver, Power MOSFET x 2.
Forms the basis for a receiver module for dimmer control of 12vdc LED strip.
Transmitter/Controller yet to be designed.
Thanks in advance for any help.
