Hello everyone,
So I've hit a real stumbling block with this new project I've taken on, given that this is my first "major" dive into analog/AC circuits. My setup so far is that I have just a basic, hand-wound coil of wire attached to my oscilloscope probe. I am using this to try and read data that's coming from a wireless source (bits are 5 microseconds in length). My Rigol does a great job of showing me that I am indeed seeing the data in the coil, but unfortunatly it does not have a fast enough record rate to record all of the data, so now I need to make a DAQ that is capable of recording this info. My biggest problem is that, since this is an inducting reader, the signal spans -1.5V to 1.5V, and I've never really dealt with anything other than DC signals. My first thought was to use everyone's favorite, an Arduino, to try and read the signal. I had no real idea how to hook coil up to the Arduino, but decided that I should probably test my max read speed, not including sending the data. Finally breaking down into asm code and setting the analog-read prescaler to 2, I wasn't incredibly confident that it would do what I want. My next thought was to use a comparator (another component I'm not familiar with) to simply convert the signal into a digital one, which I can then either hookup up to my Arduino or my Altera-DE2 to do the acquisition without having to worry about an ADC MUX to cycle through. My big problem with that is I have no real idea how to hook up the coil to the comparator. I first thought to pass it through an amplifier. First chip that came to mind was a LM324, but I have no idea what to hook up to the V- terminal. I read that it needs to be negative voltage, which can be generated with a 555 timer charge pump, but negative voltage sourcing is even more alien to me than AC signals.
In short: What would be the best way to go about recording a signal that is being captured using a inductor coil probe? How would one go about hooking a coil probe up to a comparator(I feel this is probably my best bet), or to an op amp?
If I get some free time later from research, I will try to hunt down a mouse to draw a semi-decent picture of what I'm trying to do.
Sorry for the lack of experience, thanks for your time!
-Jon
