Yep, if you turn down/off the SCALE ILLUM knob (to the left of the power button), the display will very likely turn to the standard blue color you generally see on Tektronix analog scopes.
The scope can be fitted with a clear screen filter rather than the more common blue contrast one. - many Tek scopes were originally supplied with both. Yes, turning down the graticule illumination will get rid of the red color with these, but it will still be a green trace on a light background, not blue.All filters have a black boarder that hides some of the outside visible border.
I can't see a black border in the photo so it looks as if no filter is fitted. Check whether the scope does actually have a clear plastic filter fitted in front of the CRT glass, it needs to be there for implosion protection. If you prefer the traditional blue, then blue filters can be picked up on ebay or other surplus outlets (particularly in the US).
P.S. Make sure you get one for the correct model (or series) as their shapes vary.
