Author Topic: Reduce the thump sound from a analog drum circuit  (Read 1570 times)
Offline nathanpc
  • Country: br
    • Innove Workshop
« on: June 06, 2016, 05:17:29 am »
I've been thinking about building a drum machine for quite some time. To start things out I decided to look for some of the basic circuits that are required for it, so I stumbled across this circuit and decided to try it out. It does produce a very convincing sound. This is the circuit I've prototyped on a breadboard:
The only difference is that I'm using a LM358 opamp and the input is a push button with a 10k resistor to ground and a 10k resistor to the 9V rail, but I'm having a bit of a problem (or maybe the circuit is supposed to be like this and I'm just being dumb), as you can see are are two very loud thump sounds when I press the button and when I release it, what can I do to remove, reduce or improve the circuit to have a better drum sound?
Offline sync
Re: Reduce the thump sound from a analog drum circuit
« Reply #1 on: June 06, 2016, 05:57:57 am »
You need a short pulse on the input. Maybe 1ms. When using a single supply the input should be about V+/2 with the short pulse to V+ or ground.
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #2 on: June 06, 2016, 06:46:36 am »
Oh! Thanks very much sync! That solved the problem it's now working great!
Offline Zero999
  • Hero999
« Reply #3 on: June 06, 2016, 07:00:24 am »
Yes, you were saturating the op-amp too.
How are you generating the short pulse? You could try a piezo transducer or a monotstable+ switch.
The LM358 isn't the best opamp for this because it suffers from crossover distortion.
« Last Edit: June 06, 2016, 07:04:56 am by Hero999 »
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #4 on: June 06, 2016, 07:08:20 am »
Hero999, for now I'm using a PIC with a super simple program to turn on a MOSFET for about 1ms when I hit a switch, but the finished project will be controlled all from 7400/4000-series logic and a huge amount of switches.
I'm using the LM358 just because it was the first thing I saw on my bench haha, in the final design I'll probably use the LM833 since I have a massive amount of them.
Offline sync
« Reply #5 on: June 06, 2016, 08:29:05 am »
Btw: the real 808 drum voices using more complex circuits. For example the base drum. TRIG is the trigger shared with all voices. It's a positive pulse. When an accent is played the amplitude of TRIG is higher. BD selects the base drum. See the TR-808 service manual for more information.
Offline amyk
« Reply #6 on: June 06, 2016, 02:26:08 pm »
I thought drums were supposed to make a "thump" sound. :D
