I was curious if anyone had a simple to implent method of reducing standby current to a device and to protect a LiPo battery from draining completely. Let me describe the device. The device draws about 350 mA during use but I want to have a soft on-off as well as a timer off so that the device shuts itself off when it's not being used. The device is powered from a 850mah 7.4V battery and it goes to an on-board 5V switching regulator.
Does anyone know of a way to protect the battery from draining below 6v and also allowing a low current (or none) with a soft on-off-sleep? this device is going to be used sporadically so if the battery is dead all the time, that'd suck.
Any help would be appreciated.
