Hi There!
I put together a simple USB based reflow oven controller. I am interested on your thoughts on the design, if there is any flaw in it. I am pretty newbie, so there might be. It uses a ATMega328P as the main controller and a FT232 for the USB connection. A MAX31855 is used to convert the thermocouple voltage levels to usable ones, it will also use a electromechanical relay to turn the oven on and off.
I am not quite sure if the FT232 3.3V out's 50mA is enough to drive the MAX31855, or if I should use a dedicated voltage regulator. Also unsure if the USB connection needs protection fuse and/or a ferrite.
Thanks all!
