I'm designing a board that will fit inside my old Heathkit clock, get the time from GPS, and set the clock. The circuit is designed and tested on a breadboard, the software is written, the PCB is designed; I'm almost done. But then I thought: what about the heat?
The clock, a GC-1107, runs off 8V to 21.2V. The voltage is varied in response to the room's ambient brightness so that the display brightens and dims. I need to get 3.3V, 80mA from that for my board. My first thought was to use a linear regulator, rated for at least 150mA, in a SOT223 (I'm using SMD since space is tight: my board has to fit inside the Heathkit case). But then I started looking at heat and it looked like that poor little SOT223 would be generating about 6W. I'll bet it wouldn't be generating it for long. :-)
How can I sink that kind of heat? Is there a ghost of a chance my PCB traces would provide sufficient sinking? Should I switch to a TO-220 with a heat sink and just try to fit it in? Is there a more heat-efficient way to cut 21.2V down to 3.3V without taking up too much real estate?
Thanks,
Bob
