Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
relay coil voltage problem
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: relay coil voltage problem (Read 2007 times)
SnakeBite
Regular Contributor
Country:
OBSESSED MODDER
on:
June 08, 2014, 07:46:41 pm »
i designing an battery operated product that has voltage range of 11-14.4V and i'm using a 12v coil relay. in the datasheet says the min coil voltage is 9.6V and the maximum voltage is 13.2V. what is the simplest way to lower the voltage to the coil voltage range of the relay?
here's the relay's datasheet
http://www.mouser.com/ds/2/307/ly_dsheet_gwj002-e2-10-48034.pdf
i thought about using two diode in series but it's tricky to get exactly 1.2-1.4v voltage drop with 75mA.
thanks
Ido
Logged
Ido Aricha , Israel.
retrolefty
Super Contributor
Country:
measurement changes behavior
Re: relay coil voltage problem
Reply #1 on:
June 08, 2014, 07:52:45 pm »
Well if you look up the coil current then you could calculate a series resistor that drops 1.2 vdc when the battery is at 14.4 vdc.
Logged
Fank1
Regular Contributor
Reply #2 on:
June 08, 2014, 07:52:59 pm »
Personally I would not worry about it, but just put a 16 ohm resistor in series with the coil.
At 75 ma this will give you a 1.2 volt drop.
Logged
Andreas
Super Contributor
Country:
Reply #3 on:
June 08, 2014, 08:26:33 pm »
Hello,
You are simply using the wrong relay.
There exist other 12V relays with 9-16 or even 9-18V operating range.
BTW. the upper voltage is usually for the upper operating temperature point.
If you dont need the whole temperature range you can usually allow for higher coil voltages.
With best regards
Andreas
Logged
SnakeBite
Regular Contributor
Country:
OBSESSED MODDER
Reply #4 on:
June 08, 2014, 08:40:00 pm »
thanks guys
Logged
fcb
Super Contributor
Country:
Test instrument designer/G1YWC
Reply #5 on:
June 08, 2014, 10:28:32 pm »
I wouldn't sweat it, it's probably just spec'd at 13.2V to allow for indefinate on time at peak operating temperature. If you plan on running the coil for along time, look up 'coil economizer' circuits.
Logged
https://electron.plus
Power Analysers, VI Signature Testers, Voltage References, Picoammeters, Curve Tracers.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
