A while ago I realized that I had hit a brick wall. I was reading through my books and trying to absorb more of the basics, but what I could try for myself was limited by the fact that I don't own a function generator. This made it very difficult to do my own experiments with AC signals.
I looked for function generators and most of the ones in my price range seemed very limited. Then I found a project which promised 20MHz for far less than most 5MHz scopes sell for:
Project (It wasn't until I reached the end of the page that I realized who had created it!
http://alternatezone.com/electronics/hsfg.htmSchematic
http://alternatezone.com/electronics/images/hsfglc11.gifI needed to buy the vital MAX038 IC on eBay from China because I couldn't find any other supplier who still carried it, and I couldn't find any other similar IC currently in production. So I waited a few weeks for the chip to arrive and then I built the circuit. Immediately the current limiter light came on in my power supply. I looked it over and couldn't find anything wrong. So I tore everything out and built it again from scratch. Same problem. Then I looked over again and noticed that R6 which should be 6.8 ohms and connected to ground was actually 6.8k ohms and connected to -5V.
After checking all other connections once more, I started it up again. Current limited.
At this point I wasn't sure whether there was another problem with the circuit or if I'd made the IC so crispy that the short was permanent or if the IC was a dud. I decided that I could always get another IC and went ahead with some troubleshooting. First I removed the IC and applied a voltage to the circuit. There was no short. Then I put the IC back in and checked the current through each individual pin, only keeping the circuit powered for as long as it took my meter to register. I checked all of the grounds. Nothing. Then I checked V
EE and saw a large amount of current. I figured that the current must be coming from V+ or V
CC so I removed each of them one at a time. Bingo. Having V+ but not V
CC connected solves the shorting problem. The circuit still doesn't work, but I figure that I abused the IC so much that it's beyond help.
Fast forward a few more weeks. I have a new IC and I've dropped it into the modified circuit (after checking it again). The new IC immediately activated the current limiter (which was set much lower this time). As a sanity check I put the old IC in its place. Still didn't work, but there was no short. I can't imagine why the new one is shorting but not the old one. Or why all of the current appears to be shorting straight from +5V to -5V.
In short (pun not intended), I have a few questions:
- How reliable are these clone (at least I assume they are) ICs? I expected it to at least work long enough to verify that the circuit works.
- Is the chip at fault or have I overlooked something huge?
- Where is a good place to buy old parts? 99% of the MAX038 sellers are in China and I suspect that the other 1% could have easily bought the clone version and are reselling at a premium.
