Author Topic: remote control works if no motor is running on the same 120 volts line  (Read 4080 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
I build this and it works. Here is the but.
If I am running on my treadmill.  It keeps false triggering like a ratle snake.
Any  clue?
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline Neilm
Re: remote control works if no motor is running on the same 120 volts line
« Reply #1 on: January 27, 2014, 07:16:10 pm »
I would guess that the treadmill is putting pulses of noise onto the mains. This is then getting through your wall wart and introducing pulses onto your power supply. If the pulse is enough it will appear as if a pulse has been received.
I would try adding some more filtering to the supply input.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: January 27, 2014, 07:51:47 pm »
Hate to break it to you, but this schematic is terrible.
There is no need for current limiting in this circuit. You don't have any unknown loads on your supply line.
That TSOP17 IR receiver has an absolute maximum output current rating of 5mA, which is definitely exceeded when you are discharging a cap through it + shorting the supply rail through that PN junction of that PNP. The receiver could already be damaged.
The circuit reacts to pretty much any 38kHz IR signal. ANY. You threadmill could just be outputting an IR signal for some sort of isolated PC communication (kind of like the one you find on multimeters).
Use a small microcontroller (like a Tiny13) to decode the signal from the receiver and trigger the relay. A lot more reliable and you can also program the exact codes into it.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #3 on: January 28, 2014, 01:55:45 pm »
I gess both of you are right.
Is there adaptor for the motor to line?
I know almost nothing about pic...  Guess I will have to learn a bit of it.
Thanks.
JP
Offline zapta
« Reply #4 on: January 28, 2014, 04:19:06 pm »
Cover the IR detector with opaque tape and run on batteries, do you still get false triggering?
« Reply #5 on: January 28, 2014, 04:59:47 pm »
Nope.
On battery, even if I dont cover the IR it does not false triggering. It just work.
Thanks for your free attention.
« Last Edit: January 28, 2014, 05:48:10 pm by J4e8a16n »
Offline zapta
« Reply #6 on: January 28, 2014, 07:19:44 pm »
Nope.
It looks then that the noise comes through the power supply. Try to add capacitors on the dc lines before and after the regullator.
« Reply #7 on: January 28, 2014, 09:26:04 pm »
Well...
I redid the test with the battery and it does trip.
Offline Dave
  • Country: si
« Reply #8 on: January 28, 2014, 10:22:14 pm »
Why even bother making a forum thread if you are just going to ignore the responses? ::)
« Reply #9 on: January 28, 2014, 11:09:03 pm »
I tried the capacitors.
then I redid (do again) the test with the battery and it does trip.
so I am lost.
« Reply #10 on: January 29, 2014, 03:02:18 am »
The transistor was damaged  while opening the casing. I replaced it.
So there is no tripping has before when I am on battery.
I added a capacitor before and after the regulator.
Here was the problem;
I putted back the metal box around the ir receptor.
It does work with the thredmill on the circuit.
Why?
Thanks for your help.
« Last Edit: January 29, 2014, 10:51:32 am by J4e8a16n »
