Author Topic: removing smoke smell from old electronics  (Read 20852 times)
Offline M0BSW
  • Left this site 2013, they will not delete it ????
Re: removing smoke smell from old electronics
« Reply #25 on: August 04, 2013, 04:47:29 pm »
Green fairy washing liquid.......
OK Sean we have that, I've just learn that the  Little Chef road side cafes are now own by Kuwait, I really don't think we own anything in England now. Green fairy is called Fairy liquid over here.
Given the amount of oil they use in frying stuff, I guess that's appropriate.
:-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD Nice one :-+
no one would or will tell me how to delete this account
Offline Spunky
  • Country: wales
« Reply #26 on: August 05, 2013, 12:15:50 am »
Yep and for the case and knobs and such - Simple Green.
What is simple Green , I've not seen anything called that in the UK.
I guess you don't have Google there either.
Anyway, how do you get rid of the smell of Simple Green?  I think I'd rather have the equipment smell like smoke.
Oh Yes we do, that's how the American government keep tabs on us see what we are doing over here, now all the bases with the spy planes have gone :-DD, and we have super fast broadband to  Google that's old school.
Nope, still got them. There's a base by me flying UAVs all over the place. Noisy buggers they are too.
Offline Stonent
« Reply #27 on: August 05, 2013, 05:28:23 am »
And for those who haven't used it, Simple Green has sort of a strong licorice smell to it.
Offline peter.mitchell
« Reply #28 on: August 07, 2013, 09:57:10 am »
In a hot climate this may be slightly risky, though, as the heat may locally exceed what the components and synthetic materials can take for very long.
Really? If anything designed for day to day use can't stand say... 12-18 hours in direct sunlight at say 40 degrees celsius, it's probably FUBAR anyway.
Offline amyk
« Reply #29 on: August 07, 2013, 10:38:07 am »
Plastics are known to be attacked by the UV in sunlight.
Offline M0BSW
« Reply #30 on: August 07, 2013, 12:05:36 pm »
I think we only got Lakenheath now in east anglia, glad when Alconbury closed, the SR71's they were noisy buggers to,it was the A10's Warthog's , that scared everyone where I live, the buggers kept on falling out of the sky,and they flew around with live ammo, that was frightening to.
Offline dentakuTopic starter
« Reply #31 on: August 21, 2013, 03:34:01 pm »
Just to add to this old-ish post. I tried to remove the smoke smell from the enclosure of the B&K Precision 1472C but it's never going to go away SO this morning I tried to sand the paint off but it's too thick and soft.
I ended up using Circa 1850 paint remover and was able to pull the paint right off like a big sheet of rubber. Hopefully that will get rid of the smell.
I might paint it again in a nice blue similar to my Toyota :) A $40 15MHz scope isn't really worth the can of paint but it's still a fun experiment.
The plastic stuff cleaned up nicely enough with Mr. Clean Magic Erasers, Eco Green cleaner and Car Febreeze.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #32 on: August 21, 2013, 04:01:46 pm »
That is why I use Crystal Simple Green, same stuff without the overpowering smell and green color.
« Last Edit: August 21, 2013, 04:36:24 pm by robrenz »
Offline KJDS
    • my website holding page
« Reply #33 on: August 21, 2013, 05:33:38 pm »
Try using plastidip to give it a new coat
« Reply #34 on: August 21, 2013, 08:20:25 pm »
I found a simple way to make it look nice without bothering with paint.
I took a palm sander with some 100C Aluminium Oxide paper and vigorously sanded the whole newly stripped and slightly scratched up enclosure so it's all shiny with a little random texture to it.
I wonder if it matters that now I've removed that non conductive rubbery paint?
I doubt it because there were exposed unpainted rivets all along the bottom.
« Last Edit: August 22, 2013, 02:24:47 pm by dentaku »
Offline Stonent
« Reply #35 on: August 22, 2013, 02:07:10 am »
I seem to remember that RAF Lakenheath has the only Taco Bell in England and maybe Europe.
Edit: Nope, there's two in Essex and one in Manchester.
« Last Edit: August 22, 2013, 02:09:30 am by Stonent »
Offline LEECH666
« Reply #36 on: November 08, 2022, 01:31:53 am »
I find that washing with isoprop works the best for me to remove the dreaded smokeing smell.
