The video is available in 4K. The scale is graduated in millimeters just for reference.
A broken iPad 2 flex cable, chepo soldering iron, and hair sized enameled wire.
I just wanted to share it with you guys.
I actually soldered through the viewfinder, which made my life much harder, because I had no sight of view, due to the really narrow distance of the camera lens. Almost burned the camera tho. hahaha
It worked in the end, no need for expensive stuff.
