Dear All, Hi,I have a HP laptop DVD writer which has an IDE connector & is now unused. I want to use that writer as a portable dvd writer to my PC.So i want to make a circuit which converts IDE to USB. Mini USB type port & can use 5V USB voltage to write any DVD.Kindly suggest.
the circuit is simple enough and mostly 1 ic.the problem is getting that ic....simplest way is to buy a usb enclosure for a harddisk and get it from there.
Quote from: free_electron on September 23, 2012, 04:28:36 pmthe circuit is simple enough and mostly 1 ic.disagree with respect sire. powering up 12V device from 5V supply? IDE is big device isnt it? circuit to ensure its stable? connectors? cable? casing for lesser water-unproof and ease to carry portable? 1 ic? i dont think so.
External drive enclosure for hard drives are cheap at the OHL shop, around $20. Comes with a power supply and a USB cable as well, and handles IDE and SATA drives. Add a cheap converter board ( 2 connectors and nothing else really) and away you go. Otherwise a USB to IDE/SATA portable dongle will work as well, as it will most likely be able to power the laptop drive as well.
Not that any of those will be able to connect to an optical drive.
Quote from: Monkeh on September 23, 2012, 05:37:46 pmNot that any of those will be able to connect to an optical drive.However, you could buy a cheap external USB DVD-RW drive and cannibalize that for parts to make the adapter...
Or just buy the drive and use it.
Quote from: Monkeh on September 23, 2012, 05:49:17 pmOr just buy the drive and use it.I think you missed the smiley after my comment (it was a joke of course)
Eh, you yanks, crappy sense of humour.
Quote from: Monkeh on September 23, 2012, 05:55:57 pmEh, you yanks, crappy sense of humour. Not quite a Yank, though. Born and bred in Hertfordshire
i dont understand the Hertfordshire joke
Quote from: Mechatrommer on September 23, 2012, 07:15:36 pmi dont understand the Hertfordshire joke"Yank" is used outside America as a nickname for Americans. Monkeh was implying that I was, or had become, an American. Hertfordshire is a county in England, one of the so called "Home Counties" surrounding London. I am therefore English, although given my current residence I am an Englishman abroad.
