I have a resistor with five bands, Brown Black gold gold Yellow, I thought I knew how to read resistor bands, but obviously not!! can anyone shed some light on this for me.
This is probably one of those oddballs that is a 3-band value with tolerance and temperature co-efficient or something. The best question is, what value does it read when you measure the resistance with a meter?
I expect it is likely a 0.1
5% with a temperature coefficient of 25 ppm/K
...though it could be some other oddball code types too, of course, so I'd measure it to see if it is even close to something that makes sense from the colors.
5 band resistor with a 4th band of gold or silver
Five band resistors with a fourth band of gold or silver form an exception, and are used on specialized and older resistors. The first two bands represent the significant digits, the 3th the multiply factor, the 4th the tolerance and the 5th the temperature coefficient (ppm/K).
