Author Topic: Resistor decade box, component power rating  (Read 1740 times)
Offline nikodemusTopic starter
« on: July 04, 2013, 10:25:28 am »
I'm thinking of building a resistor decade box.
Something that confuses me is that the designs I've seen seem to use resistors of all-the-same power rating, typically around 1W.
I was thinking of speccing mine for up to 10V voltage instead -- so for dialed in 1 Ohm, that resistor would have to be able to handle 100W, for 2 Ohms the second series resistor would need to handle 50W, for 3 Ohms the third 33W, etc.
Seems that a fixed-voltage specced box would just be much easier to use when working on eg. battery powered devices.
Am I missing something? Is it just assumed that these boxes are used only with current-limited power supplies, or is there another reason why a max-power spec instead of max-voltage spec is typical one?
Offline george graves
Re: Resistor decade box, component power rating
« Reply #1 on: July 04, 2013, 11:25:42 am »
Do you know how big a 100W resistor is?
The reason why you can get away with smaller resistors is that you generally only use it to set up low current devices.  Setting up op-amps and voltage dividers, led brightness.
https://www.tindie.com/products/redrocketlabs/resistance-decade-box-resistor-substitution-box/
If you're looking for something that you can use to put a "load" on a battery - take a look at Dave's "dummy load" project.  It's a easy and fun build for a beginner.
« Reply #2 on: July 04, 2013, 01:47:49 pm »
Thanks for the response!
Even more pertinently, now that I actually think about it, ... no matter the size of the resistor, I really don't want to think about the heat sink something able dissipate 100W would need!
