Hello, I know it is not the best way to solve this problem, but just for the sake of learning. Let's say I need 3.3V but my transformers output is very high, say 17V, plus the transformers's regulation is pretty high (drops to 12V at 300ma). 17V s is to high for my favorite low drop 3.3V 662K. So I tried to use two regulators in series, first regulate down to 5V using 78L05 and then feed 5V into 662K. But I am getting about 2.3V instead of the expected 3.3V volts. Any idea why? Headroom shouldn't be an issue. I measure 5V at the output of the first VG and the same 17V DC at the transformer output. (This is a small cheap electronic transformer that outputs 12V DC at 300mA).
Also, I am thinking shouldn't I be able to put a simple resistor divider in front of a VR? I understand this is inefficient, but shouldn't this work since a VR's input impedance is very high?
