This was just a simple learning circuit with 3 resistors in parallel connected to a 6V lantern battery. Wires were checked for accuracy compare to diagram. The only thing is the experiment called for values between 1K and 100K but we had a 1K, a 220 Ohm and a 470K in the circuit. I didn't think it mattered but as soon as it was connected to battery the 220 started smoking. So I'm wondering if the reason for 1k-100K values were necessary for some kind of compatibility?
I wound up replacing the 470K with a 22K and the circuit worked. Maybe it was just a bad resistor.
Edit: Sorry, I am enlarging the diagram but when attaching it doesn't seem to enlarge.
