Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Resistor watt rating for high power opamps
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Resistor watt rating for high power opamps (Read 1176 times)
sean87
Regular Contributor
Country:
EE WannaBee
on:
May 31, 2017, 08:40:41 am »
Let's say you want to use a power opamp to amplify a small signal into a big one. The opamp would output something like 50V@2A.
In this case, does the resistors of the feedback/input (e.g. R1 and R2 in the above picture) stage need to be of a high watt rating? Or I can get away with normal resistors or even SMD 0806 resistors? which are maybe around 250mW rated or less?
Logged
EMBEDONIX
- Embedded Systems, Linux and good stuff!
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Re: Resistor watt rating for high power opamps
Reply #1 on:
May 31, 2017, 09:39:56 am »
Generally speaking no, The Power OpAmp inputs "look" electrically like
a normal hi-z input, so no significant current is drawn, and input and fdbk
Rs just function as a voltage divider to set loop feedback factor.
Regards, Dana.
Logged
sean87
dmills
Super Contributor
Country:
Reply #2 on:
May 31, 2017, 09:45:19 am »
R2 power dissipation is set by the maximum output voltage P=E^2/R in the obvious way.
R1 power dissipation is set by the maximum input voltage (same eqn).
This follows from the observation that the inverting input of the opamp is a virtual earth node.
Note that resistors have a maximum voltage as well as a maximum power rating, both must be respected.
Regards. Dan.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
