When replacing a through hole resistor on a board, in absence of schematics, its important to
evaluate the power rating of the resistor in place,
but I cannot find good information on this point. Can you help ?
I understand that size may not be sufficient as it will evolve with time,
but let us assume that we are in presence of a modern ( < 20 years) product
with some other resistors on the board that can provide additional clues.
Is there a good reference somewhere for the relation between size and power rating ?
In particular, the resistor I am looking for at present is 4mm x 11mm . What could be its power rating ?
Edit : I have since found this document
http://www.sunroc.hk/index.php-view=article&catid=43-resistor-series&id=257-forming-resistor&option=com_content.htmIs it reliable.
From it, I would deduce that my resistor is 1W . Is it OK ?
