This is probably covered in all Electrical Engineering classes 1:1 - but since I'm color blind I've always just skipped this chapter after yet another try where I totally fail to tell what colors each band is on a resistor.
However, I have a rather large one that my ohm-meter isn't really too precise about. It looks like 0.2ohms but I'm not sure, so I thought well, this is nice and large so I tried to use the color codes. ARGH - sorry, which side is which here? I see what looks like silver in the middle - it's definitely NOT white or gray and no chart I've found shows silver in the middle! I know these large power resistors aren't exactly common, the little ones I can barely see there are color bands, let alone the color and of course with SMD we just look at the code under a magnifying glass and look that up. So I guess this skill is going a bit out of fashion, but I would still like to know from the old-timers here. I took a picture to clarify my "dilemma". First how do you tell which side is "first" and second, am I seeing it right that silver is in the middle - which may explain why I cannot see how the color codes would cover <1ohm resistors ... so maybe my chart just doesn't take into account that some resistors are less than 1 ohm.
My quest is to learn so a link to something that explains this would suffice. Thanks!
