There's a project running here to build a current probe, there are basically two types for isolated current probes, transformer and hall effect.
The transformer is great for pecission, high bandwidth ac measurements, you can wind one yourself to match your requirements for thebresistor you want to use and the voltage range you need or use a standard transformer like the ones provided for power meters, where you can get the meter and the transformer for $7.
The hall effect sensor allows to measure DC but specs don't go up as nice as in transformers, then you can use them cuttiing a toroid core in halfs to build a clamp or as pass elements with the available ICs, the one with the core is quite easy to go probing arround but the others come calibrated from factory but you have to pinch the wire.
If you have a floating or ground referenced thing to measure you could do with a resistor and an amplifier as the μCurrent, wich is really nice in those cases, DC with really good precision and low burden voltage.
JS
