I'm currently designing an active RF probe (1MHz - 1GHz). I have a prototype designed, however, I have run into an issue.
Im able to impedance match all the components (doesn't really matter since the distance between nodes is very minimal) fine. It's the input impedance that Im having issues with.
The input impedance is meant to be in the order of megaohms (1-10 Mohm), but due to the nature of the internal capacitances (most likely body or cgs), the input forms an (almost) direct short to ground. Its not possible to place a high value resistor in series with the gate as that just forms a low pass filter with the capacitance which is causing the impedance to drop.
It seems like there's a massive tradeoff between bandwidth and input impedance. I know that there will always be a compromise between specifications, but is there a way to alleviate the issues? Is this something thats impossible to combat since you'd always have some form of junction capacitance? Could this just be an over-conservative model of the bf998 that Im using?
I've tried experimenting with both common source and common drain topologies, both present the same issue.
Schematics:
