Since you seem to be after a canned solution, instead of a home-rolled one, you're looking for MMICs (Monolithic Microwave Integrated Circuits). From the datasheet, you'll still need to use their matching network (page 9) before you drive anything else. An amplifier like the Analog Devices' ADL5536
might do the job, but its P1dB compression level is right at your output want. You would also need an attenuator to knock your output power
down before gaining it up. Overall, this might be the most easy option if you don't mind the distortion introduced from the compression.
Personally if linearity is important, I might use an off-the-shelf power splitter, use two of the amplifiers, then another splitter as a combiner. (Something like the minicircuits SBTCJ-1W+
http://www.minicircuits.com/pdfs/SBTCJ-1W+.pdf). This route offers a few benefits for the cost: A 6dB attenuator feeding a 3dB splitter means 3dB of my power is actually doing something useful. When I gain up the two signals, they each stay below their compression point so they're more linear. Combine them again to get the 3dB summation boost. 20dBm with good linearity, at the expense of cost and power (the ADL5535s burn a lot of it).
