Your question is kind of vague... careful or people will accuse you of asking us to design the whole thing for you.
That being said, you can connect several LEDs in series until the forward voltage starts to approach the supply voltage. For example, if the forward voltage of the green leds was 3.4V (and Vcc = 12v) , you could not have more than 3 in series because a 4th one would make the total forward voltage greater than your 12V supply.
Also, you cannot directly parallel LEDs of different colors (i.e. they cannot share a single current limiting resistor). The reason is that the LED with the lowest forward voltage (usually red) will steal current from the other colors.
