Hallo,
my Englisch is not the best, but I try to explain my problem:
The Rigol DS1054z is new with the latest software!
The rigol ist connected directly to the power supply system.
All probe inputs are connected to GND
Trigger is set to "auto"
Channel 1 is on, measurement system is also on.
Time base is set to 10ns/div (changing time base has no effect)
I measure the following when time base (V/div)
is set to:
V/div Vpp ca. Vrms
1 V 40 mV 34 mV
5 V 600 mV 215 mV
0,5 V 20 mV 15 mV
What I am measure seems a square wave with 8ns
The beam is not in the zero position and shows the same voltage as I measure with the measuring system.
Normally, when I put all probe inputs to the ground, the beam has the position in the middle of the screen and I measure zero voltage.
Can someone test this effect or explain it or is my Rigol wrong and I must send it back?
Thanks to all
Best regards
Reinhard
