Is that 50 ohm termination inside the 485?
Yes it is, and all the better for it Presumably Tek learned from the HP1740a - and improved on it by disconnecting the 50ohms in the event of an overload.
Quite surprised to see that level of ringing on a Z0 probe with spear. TBH at that level because my crappy old Tek probes taper off at about 70MHz, and I'm too cheap to buy some nice ones, I built my own probe with a bit of quality RG58U and a couple of hand picked resistors and soldered it in circuit. No internal termination on my 465B though. Worked like a dream however
So am I. I think the 3*CMOS may be partially due to a longer track (<2cm) than desirable. Maybe I'll chop the track and see if it makes a difference. The other possibility is that a 100nF 0603 for each gate isn't sufficient decoupling.
OTOH, there's no such issue with the 1*CMOS, and the ringing is still there at the same frequency, albeit lower amplitude.
Hence I suspect it is the CMOS output being agggressive.
I've increased the decoupling capacitors from 100n to 4u7 0603s. This has reduced, but not eliminated, the switching perturbations on the 5V rail. On my scope 350MHz Tek485 it makes very little difference to the oscillograms, except that the overshoot on the 3*CMOS driving 50oms is reduced. That suggests the CMOS outputs are being aggressive.
FWIW. the best I can do with an unterminated output is about 510ps with a single lvc1g14, probed with an Agilent 1130A 1.5GHz single ended FET probe with browser on an MSO7104B.
Ah, the joys of having more than obsolete hobby equipment
I've made indirect measurements of the transition time by driving the 3*(LVC14+130ohms) from an AC coupled noise source and looking at the result on a spectrum analyser (an SDR dongle, since my Tek492 isn't immediately available). Eyeballing the transition between the 20dB/decade and 40dB/decade rolloff indicates a transition time of around 600ps, which isn't too far from your results.
Is that 130 ohm a "sweet spot" for the LVC series? I can see three of them plus the inherent device's output impedances reasonably showing as a 50 ohm source.
That's the intention, but quite frankly I don't have a means of validating it. Hopefully the 130ohms will not only reduce ground bounce and decoupling effects, but also reduce the effect the gate's output impedance changing with output voltage.
I've attached a picture of that output stage. Given the equipment available to me and the expected transition times:
- I think the BNC connector is sufficient
- there's no real attempt to get the PCB track to be 50ohms; I suspect it is around 75ohms
If I re-spin the 2 layer 1.2mm board, I might change that plus make the 5V rail into a more complete plane.
