Select mode = memory, and use the center attribute button to move
the display. Will occupy ~ 3/4 of screen.
As far as utility of FFT ve traditional swept spectrum analyzer. The latter generally has
a much greater dynamic range, > 100 db, and a 50 or 75 ohm environment. That being
said a great deal of work goes on where 60 db or even less all thats needed, and very handy
mixed mode display. I find both approaches of equal value depending on task at hand.
Regards, Dana.
