Author Topic: Running a power supply with no load  (Read 826 times)
Offline institches
« on: March 07, 2018, 10:43:51 am »
I was wondering if it's safe to run a power supply from an old computer (Amiga) with no load. I think it's linear? I'm assuming that because it uses transformers. Sorry, a bit new to this.
It has +12V, +5V, -5V supplies.
The main reason I ask is because I'm looking to replace the caps and I would like to measure the output noise before and after cap replacement out of curiosity.
Should I be running it under load to get accurate results anyway? If not, is it safe to run any or all of the rails with no load?
I've heard it is not good to run an PC ATX power supply with no load but I really was looking for confirmation.
If anyone feels inclined, can you explain why a load is required.
Thanks.
Offline Wimberleytech
Re: Running a power supply with no load
« Reply #1 on: March 07, 2018, 11:02:23 am »
For linear power supplies, a load is not required.
The following users thanked this post: institches
Offline respoda
« Reply #2 on: March 07, 2018, 11:15:33 am »
I thought pc psu's are switch-mode, not linear, and do need a dummy load ?
I'm in the process of building one too, so I do believe you need some kind of a power resistor to act as a dummy load to keep the device running with no real load attached.
edit: since it has a +12v, +5v and +3.3v lines, it is switch-mode, so the above 'should' be correct.
The following users thanked this post: institches, EddyK59
« Reply #3 on: March 07, 2018, 12:16:52 pm »
Yes
yes
You can easily make a linear power supply with these voltage outputs.
Offline Circlotron
« Reply #4 on: March 07, 2018, 12:24:39 pm »
The Amiga supplying will be just fine without a load. You should measure the noise with various loads though. I used to have an Amiga back in the day and I remember the power supply box being fairly heavy so it was a linear supply, not like normal pc supplies.
The following users thanked this post: institches, respoda
Offline institches
« Reply #5 on: March 07, 2018, 02:07:50 pm »
Thanks all.
That clears things up.
I'll be applying a load to my old Amiga (linear) power supply, not because it needs one but because it is recommended for accurately measuring noise.
The following users thanked this post: Wimberleytech
Online james_s
« Reply #6 on: March 07, 2018, 03:46:45 pm »
The Amiga 500 uses a linear power supply. The A2000, A3000 and A4000 use internal switchmode power supplies. In any case running without a load won't damage anything, it just won't give accurate measurements.
Offline institches
« Reply #7 on: March 07, 2018, 06:54:57 pm »
Thanks @james_s It's an Amiga 2000.
As an aside, is there an easy way to identify the two types of power supply?
From what I've read, switch mode supplies will have smaller transformers than an equivalent linear supply.
The one I'm looking to measure has two transformers.
Offline xani
« Reply #8 on: March 07, 2018, 08:05:07 pm »
How it behaves will depend on power supply. Some with minimum current requirement will not work properly, the weirdest one was one honeywell power supply that would "cycle" (enable, then disable power) slowly when under no load (IIRC that was documented behaviour in datasheet) and generate loud high-pitched noise (switching freq) when below minimum current
Online james_s
« Reply #9 on: March 08, 2018, 04:40:49 am »
Weight is a reasonably accurate way of identifying which is which. A linear power supply will have a big chunky iron transformer and will be quite heavy. A switchmode power supply will have a much smaller transformer, usually mounted directly to the PCB. If it's more than about 80W and you can hold it comfortably with one hand it's probably a switching PSU.
Offline vk6zgo
« Reply #10 on: March 09, 2018, 12:15:54 am »
Some switchmode power supplies need a load, but others are quite happy to run into an open circuit.
Early Philips TV SMPSUs would "hiccup" if used without a load, but all the Sony ones I ran into didn't care.
Offline institches
« Reply #11 on: March 13, 2018, 09:44:03 am »
I have a PC ATX switch mode power supply I'm going to use as a test bed for applying loads and if we assume it needs a load to avoid damaging the supply, do I need to load down all available rails or just the one under test?
e.g. If I want to test the 12V rail and load it down but don't load down the 5V, could that cause damage? If no damage will be done I could use a single DC electronic load to measure each rail individually.
Online james_s
« Reply #12 on: March 13, 2018, 02:37:11 pm »
Running it without a load won't damage it but it won't work properly either. You need some load on the main output or the voltages will all be too low. On those old ones it's normally the 5V output that needs a load.
