Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Russian Capacitor Tolerance Code
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Russian Capacitor Tolerance Code (Read 1265 times)
rstor22
Regular Contributor
Country:
on:
July 15, 2016, 09:09:40 pm »
On eBay some sellers have high tolerance Russian capacitors with the tolerance indicated as 0.5% on the capacitor itself, for example:
http://www.ebay.com/itm/8000pF-350V-0-5-ex-USSR-Silver-Mica-SGM-Capacitor-Hi-End-16pcs-/252013310113?hash=item3aad29f0a1:g:2hAAAOSw~gRVk7~D
I see some listings which advertise 0.5% however on the capacitor itself it is marked as +/-5n0 (crossed out zero)
http://www.ebay.com/itm/1000pF-350-V-PRECIZE-0-5-LOT-OF-2-RUSSIAN-SILVER-MICA-CAPACITORS-SGMZ-A-/272294625257?hash=item3f66063fe9:g:NPQAAOxyni9TDHRy
Is the second link also 0.5% tolerance as advertised? The reason I ask is that I purchased one from each seller. The 8000pF measures 7990pF, however the 1000pF reads 1030pF so I am wondering if the 1000pF is really 0.5% tolerance.
Thank you
Logged
wraper
Supporter
Country:
Re: Russian Capacitor Tolerance Code
Reply #1 on:
July 15, 2016, 09:35:32 pm »
8nF one clearly state +/-0,5%, second is 1000pF +/- 5pF which is the same as 0.5%, there is no "n" letter, it is Cyrillic "p"
https://en.wikipedia.org/wiki/Pe_(Cyrillic)
What you are using for measuring capacitance? if multimeter, no way you can expect 0.5% accuracy, especially without zeroing measurement without cap attached.
Logged
rstor22
Regular Contributor
Country:
Reply #2 on:
July 16, 2016, 03:51:04 am »
Yes. I didn't follow the zeroing procedure of the instrument which mentions to keep the cable away from AC powered devices. It now reads between 1010-1020 pF.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
