Hi all,
I was lucky enough to score an almost brand new 350AH SLA deep-cycle battery that was redundant in a big data center battery bank setup. So heavy I could hardly lift it.
I have a 50 watt solar panel I use to charge and top up the batteries in my ham shack, that power various bits of gear such as a Yaesu FT-1000MP 100 watt SSB rig.
The solar panels are controlled by a 10 amp charge controller. The transceiver runs off the big battery for a couple of hours but after that I can see the led display flickering as it's coping with lower amps.
My question has to do with what kind of 230vAC charger I can throw into the mix to help sustain the transceiver for a bit longer? At present I use a small car battery charger with selectable boost charging or automatic trickle.
I'm a little paranoid about damaging my big 350AH battery through not treating it well by using the wrong equipment to top it up.
Your advice and brilliance is highly appreciated, although I'm not any kind of expert. Throw it at me anyway - show no mercy
