Hey,
I feel like it's easy enough to find a way to solve a problem, but it's a lot harder to settle on the way to solve something. I suspect it's a learning-ability vs. experience thing, I'm sure I'm not alone in this. With all things safety-related, the lack of experience worries me at times.
Now, I'd like to switch a 2kW space-heater, being about 9A @ 230Vac, that's enough to worry me, when it'll be running 24/7, unattended, when sleeping etc.
It would be easy enough to dive into it and make a circuit myself, using TRIACs probably, but I'm very tempted to use a zero-crossing solid state relay (SSR) instead. Zero-crossing seeming nice for everything from EMI and load on the circuit, to connecting/disconnecting when carrying as little current as possible.
SSR over Triac is tempting to have a "package" that I didn't make myself, being able to just talk to it over optoisolated safe nice familiarly comfortable TTL-levels.
I emailed an SSR-vendor, asked about safety and failure-modes, and got back:
"Hi, the relays can fail either open or closed and they can catch on fire but that is not normal. They do not have any kind of over temp protection."
That's fair enough, and somewhat comforting, but not exactly obliterating any worries I might have.
I could use a 16A rated wireless lamp-switch thing, but it's really just a mechanical relay, and those can also fail over time, poor contacts leading to heating and whatnot.
Okay, I might be a bit paranoid here, but I'm curious about this for the educational value of it as well.
Any wise words on safes way to do this?
tld
(If I do end with an SSR, it'd be easy enough to include temperature-control of it in the low-voltage side, but if it fails short while overheating... )
