Hi! Few months ago I built a attenuator for my tube guitar amp(100W).
It works well, everything is fine, but when I was designing it I omitted few things because I don't really have knowledge about it.
1) So, at first, since I have a stuff that possibly can have 125 volts on input it is pretty scare to think of touching the wires inside.
The problem is that I don't know how to do a beautiful metal case for this without having this case touching wires and kill myself.
Other attenuators on the market have metal cases, so there is a way to have it safe.
How to do that? I obviously can't get access to ground through mono jack... have no ideas.
For now I just made a wooden case, eh...
here's example of commercial attenuator - as you see it's metal.
2) The second problem is that I want to protect the output transformer of amplifier from burning in case of high current, so I put the fuse on the output.... but what output should I fuse? I mean it's two wires coming out, which do I need to put the fuse on? I suppose it makes not much difference, but there must be an explanation how to do better. For now I have both wires with fuses, which is probably stupid, but anyway...
Here's some photos
