Its good practice to include bleed resistors in the design to make the main reservoir capacitors discharge safely if not in use, but the typical 'Wun Hung Lo' cheap PSU probably hasn't got them and if the primary side startup circuit has blown (and it is a faulty PSU), I've known them to give a nasty shock hours later. Why risk it?
Discharge all big caps on the primary side into a high power wirewound resistor. 27K 5W is good and will discharge a fully charged 100uF 400V cap in under 10 seconds. If you connect a multimeter on DC volts across the resistor and wait till it reads under 12V you wont have any problems. If you don't have any suitable resistors, a 40W 240V incandescent bulb is usable and will discharge the caps much quicker, but check it on mains before and after use.
