Hi all
For a while now I have been working on a little project that would see me adapting a HD camera into a pair of binoculars for the purpose of streaming live video over Skype / Google hangouts etc whilst on the move.
I first looked at the radio control community where they use small cameras for first person viewing. Whilst these cameras were small enough for my needs, the quality of the image they produce wasn't really acceptable. Another issue I faced using this method is all the cameras in that community are analogue as they send the image feed over wireless transmitters, so I would need to convert that image to digital for use in video chat software.
I then looked at implementing a standard USB webcam hooked up to a small tablet PC, similar to techniques used by many amateur astronomers where they attach webcams to telescopes. After buying several higher end webcams, striping them down, I found this method to be to cumbersome. As a general rule, the higher the resolution of a webcam, naturally, the size of the device also increased. This is a problem for me as I would like to fit the device into the eye piece of one side of the binoculars so I can still use the other with my own eyes.
This brought me to where I am now. Looking for another solution, it suddenly dawned on me that I already own the device that ticks almost all the boxes, my Samsung Galaxy S5. The video quality of my phone when using applications like Skype far exceeded any webcam I had bought even though both were streaming 720p, and strangely enough, the amount of bandwidth I was using also decreased massively which is a factor for me as I am mobile and don't always have access to wifi networks. Using this method also gave me the luxury of not having to cart around a tablet PC.
A simple solution would be to use phone cases such as the following:
This however, is again, to cumbersome for my needs.
As the camera inside of my phone is very small, I started to think, why can't I just extend the flex cable inside and just have the camera module itself in the eyepiece of my binoculars? So this is what I set about doing.
After much searching, I came across this product:
Although this product is for a Samsung Galaxy S3, the amount of pins on the connector are the same as on the Galaxy S4 and S5. Having some idea of relative scale, I estimated the flex extender would be roughly 5cm long, this meant I was going to need quite a few of these extenders daisy chained together in order to get my phone out of the way of the binoculars. So I ordered 20 of them.
When they turned up, I began looking at teardown videos for a Galaxy S5, this was pretty much a none starter as the S5 been waterproof, requires you dismantling the screen in order to gain access. Nevemind I thought, I have a very understanding wife who also happens to own a Galaxy S4. I quickly dismantled her phone only to release, although the pin configuration was the same, the socket was slightly smaller, as can be seen here:
Not one to be deterred, I then contacted a friend of mine who owns a Galaxy S3. Knowing what im like, he agreed for me to teardown his phone. A couple of minutes later and his internal camera was now external and it worked! I then continued to add more extenders, this is where my moment of glory was short lived. 2 extenders connected, still working fine. Added the 3rd and the image cut in and out. I tried different extenders, same result. 4 extenders and the phone could not recognise the camera was connected.
This is where I am at now. I would like to add, no phones were harmed during this experiment
I came to the realisation that with every extra flex extender, there must be an increase in resistance which is stopping the camera from functioning properly. What I don't know is whether this extra resistance is been created by additional connecters in the loop or whether it is the length of the cable, or both. I started to think, if I could make, or have made a flex cable to my desired length (roughly 1m) thus eliminating all the extra connectors along the way, would this work?
I understand this has been a very long post and I appreciated your patience. If anyone can offer any advice whether a custom cable would work, where to get these made, or even still, a better solution that I have not considered I would be very thankful.
Once again, I thank you for your time
