While free, ExpressPCB was one of the packages i started on, its not fancy, just polished, you can rip apart and change pins easily, and export the whole thing to BMP whenever you like, (or print to PDF with external software)
Its component list is only about 500 long, with the connectors at the start, the passives and discrete active devices at the end, with the logic chips and op amps (and a few micros) packed in the middle so its easy to ignore,
and to top it all off, there library uses the actual part names, so if you search for a 741, you will find the op amp with no fuss,
I've now since moved to kicad, and i do miss the rip apart and remake of schematic items right on the page,
